Hi All,
I have a wipeout that passes AUDIT and RECOVER with no errors but when I grip edit it or do anything that causes AutoCAD to highlight it, AutoCAD Hard crashes without stopping at the "Send a Report" dialog. I have never seen this behavior before with my wipeouts (I use this same shape often). Anyone know what is causing this?
The close-in display and direct distance entry method would not return them to any location outside the circular appearing portion of the wipeout. AutoCAD crashed when I tried that. AutoCAD crashed when the wipeout was highlighted and I tried to scroll zoom.
(Note: The Y-coordinates of the circles matches exactly the Y-coordinates of the open ends of the circular appearing portion. The wipeout was originally defined to have a horizontal section that extends to where the two circles are.)
Authorized Autodesk Developer
Civil Design Specialist – Water & Wastewater Infrastructure
