I have switched from Inward to Outward, and back to Inward. No change...
Solved by Jeew-m. Go to Solution.
Solved by Jowennl. Go to Solution.
Use points codes that specify the side of the road they are on: EPR and EPL, instead of just EP, will prevent the crossing over of feature lines.
Did not work. I have attached the drawing...
Hi Todd,
Both Assemblies, Left and Right, have the same point codes: Lane, Back_Curb, Top_Curb. The codes do not differentiate between point code from one side and point code from another side.
Thanks Tim. For the life of me, I cannot find where to change the name, or add R and L.
The codes appear to be hardwired into the subassembly. Do you have the pkt file?
Yeah, these are the standard OOTB LaneInsideMultiLayerVaryingWidth.
Hi @ToddRogers-WPM ,
This is a corridor method issue. See images below. Just split them into 3 regions then turn off the middle region.
Region 1 = ok
Region 2= Use 1+08.77' - 1+18.53' <- Display off
Region 3 = ok
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
Hi TRogers,
This has happen because of your feature line. If you see at the problematic location the feature line takes a 90 degree bend. So the right side corner of the corridor also have a perpendicular shift. Even though we see it as something wrong what really Civil 3D has done is connecting the point codes as links at a 90 angle.
The case is more severe because you have set up horizontal geometry points for frequency lines. In this location your feature line has so many vertices. It has led to many frequency lines at this area and assembly has applied over the corridor at closer interval than 25'. The total mess is created by the frequency lines generated at the vertical part of the baseline called LEFT 1.
As Jowenn has proposed you can turn off a certain area to get rid of the issue.
Otherwise you can weed some PI points in the feature line and use split corridor option with some gap(as similar to jowenn's suggestion.) to avoid adding a frequency lines at the vertical portion of the baseline.
