Civil 3D Forum
Why Civil 3D cannot calculted the area for each cross sections but calculated the volume properly!?
8 REPLIES 8
Message 1 of 9
giscivil92
403 Views, 8 Replies
Hello everyone
I wonder why Civil 3d calculated the volume for each section but cannot calculate the area!?
Labels (2)
8 REPLIES 8
Message 2 of 9
nkiakas
in reply to: giscivil92
Hi @giscivil92
Did you apply sample lines in your alignment?
Can you share your file to take a look?
Message 3 of 9
Seems either you are reporting a unmatching area and volume.  e.g.  Fill Area vs.  Cut Volume.
Matthew Anderson, PE
Message 4 of 9
giscivil92
in reply to: nkiakas
@nkiakas Yes I added it already.
but I don't know what's the problem
unfortunately, it's impossible for me to send it
Message 5 of 9
nkiakas
Hi @giscivil92
Also check your table style.
Go to the column of area, and take a look if you inserted another field, not area
Message 6 of 9
giscivil92
Hello @nkiakas
I checked it already but this setting is correct and defined well.
Message 7 of 9
If you cant send the file - screenshot your table settings?  The other might be to try to run a volume report.  It's not bound by the tabular settings.
Message 8 of 9
lim.wendy
Hi @giscivil92 .
Thanks for posting. Since you've already checked the sample lines and table styles, let's try a few more steps:
  • Run a Volume Report: As Matt suggested, running a volume report may provide additional insight.
  • Screenshots: If possible, please share screenshots of your table settings and section views.
I'd also suggest watching this video by Jeff Bartels that shows the workflow for creating a Quantity Takeoff Criteria and Materials Volumes.
Let us know how it goes or if you need further assistance!
If they helped solve your issue, consider hitting the "Accept Solution" button. This helps others searching for similar problems find the answer quicker. It also lets our community know which topics are resolved and which still need attention. Plus, it's a great way to show appreciation to the person who helped you!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 9 of 9
giscivil92
in reply to: lim.wendy
@lim.wendy
Thank you dear Lim for your guidance,
Actually my work is not much the same as this, I calculated the volume between two surfaces and also I checked the points which mentioned by friends but the setting is correct.
the volume is calculated properly but the are no!
Thanks again for your support
Rail Community
