I'm working on a site that has an existing and a proposed retention pond. For the proposed pond, I created a comparison surface boundary and set the elevation for the top of the proposed pond. This gives me a volume in cu yds of 124,805 cu yds. I then convert that to gallons by multiplying by 201.98 which gives me 25.2 mil gallons.
If I use stage storage calculations, it gives me 2,048,525 cu ft x 7.48 = 15.3 mil gallons.
I've looked at the surfaces, but I can't see any obvious issues.
Is there any way to check my work?? A different way to calculate volumes? Why don't these 2 volumes match?
