Civil 3D Forum
Which layer controls Print Styles for objects with assets in different layers.
2 REPLIES 2
SZAFAS
221 Views, 2 Replies
I have two surfaces EG and FG, the default surface layer is C-TOPO and as such both surfaces are in this layer. HOWEVER i have the major and minor contours in C-TOPO-EG-MINR and C-TOPO-EG-MAJR for the EG surface and C-TOPO-FG-MINR and C-TOPO-FG-MAJR for the FG surface.
I am using a STB print style and as such i am trying to print all contours based off the layer the contour is in, the issue i am having is that the contours are printing based off of the layer the surface is in.
I cant simply put the surfaces in different layers because the minor and major would then print the same even if EG and FG would print differently now. I could use a CTB plot style to print based off the color of the contour, but i hate CTB plot styles.
I could also just export the contours but that's just a ridiculous fix and if i change anything would need to do it again and again and i refuse. lol
How do i set the controlling layer for the contours?
Labels (1)
2 REPLIES 2
tcorey
in reply to: SZAFAS
Edit Drawing Settings and set this option:
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
SZAFAS
in reply to: SZAFAS
Thanks!
Rail Community
