@avolution wrote:
Dotsoft makes an add-in for Autocad that includes a 3d offset command.
It is called Toolpac.
You're 10 years too late.
OFFSETFEATURE
This will offset 3dpolys without needing needing to convert to feature line.
I sure hope the OP hasn't been waiting 13 years for this gem....
neilyj (No connection with Autodesk other than using the products in the real world)
I am somewhat embarrassed to say that is news to me.
I'm sure that is well documented ... somewhere.
Christopher Stevens
@ChrisRS It's been a thing for as long as I can recall.....every day's a school day- although it creates the same type of object as the originating object i.e. 3D poly -> 3D poly
