Civil 3D Forum
when choosing the pressure elements, quick properties are not working
5 REPLIES 5
ishaq03
245 Views, 5 Replies
Hello everyone,
If there is a pressure network option available when choosing the pressure elements, quick properties are not working, but the gravity network operates. If there is anything in the command bar that I should fix, kindly explain it to me. For your understanding, I am sharing the images below.
Labels (1)
5 REPLIES 5
v-silvestre
in reply to: ishaq03
Hi ishaq, unfortunately I don't think pressure pipes are available at this time.  Taking a quick look within the cui, I don't see pressure pipes/appurtenances available:
ishaq03
in reply to: v-silvestre
@v-silvestre
There isn't a different way to solve this issue.
chriscowgill7373
Even in 2025 pressure pipes are not available to quick properties.  Honestly, when thinking about it, normally you double click to bring up QP, if you double click a pressure pipe, it selects the pipe.  I dont know that it knows how to handle the clicking aspect to make it available in QP.
Additionally, with the way that pressure networks function, I dont see any benefit to adding this to QP.  You cant just change information there, because the horizontal info is tied to the alignment and the vertical info is tied to a profile.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
ishaq03
@v-silvestre
Thank you for the update
ishaq03
in reply to: chriscowgill7373
@chriscowgill7373
I have recently acquired as-built data, including the invert levels of the pipes, provided by our surveyor. With this data, I believe there is an opportunity to make adjustments directly to the pipe properties without the need to create profiles. By updating the invert levels swiftly in the pipe properties, we can ensure that our information remains accurate and up-to-date without unnecessary complexities. In any case, I appreciate your advice.
Rail Community
