What happens with Nvidia Quadro and its AutoCAD performance Driver?
joantopo
Mentor Mentor
3,699 次查看
3 条回复
1 条消息(共 4 条)
joantopo
8 years ago I bought a Quadro 2000 (Fermi) and I disappointed when drivers were not available.
Now, I would like to buy Nvidia Quadro P4000 and I see that there is no support to Windows 10.. WTF!!!
https://www.nvidia.com/drivers
I can understand that there is no still support for AutoCAD 2019..... but W10?
More than 700 $......... It looks like a scam.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
0 个赞
3,700 次查看
3 条回复
回复 (3)
2 条消息(共 4 条)
DarrenP
Nvidia stopped making the autocad  performance driver years ago
i even searched for the quadro 2000 driver it no longer exists on nvidia site
there is one for the quadro 4000 but the last one was released in 2010
you use the regular drivers that nvidia provides
DarrenP
3 条消息(共 4 条)
dgorsman
AutoCAD, like a lot of engineering applications, used to be OpenGL only.  Those were the only cards which had the horsepower to do what was necessary.  Now, pretty much everything display oriented has moved to DirectX.  There's a few which still use OpenGL, either because they're supported on multiple operating systems (no DirectX on Mac, but then again OpenGL may not be getting updated on that either in the near future) or because they're using it for GPU-compute purposes.
The old "normal" drivers worked with all cards, even the old ones or new ones with limited OpenGL support; the "performance" drivers took advantage of the full OpenGL features in the workstation cards.  Now that the display system is DirectX there is no baseline/performance workaround to deal with.
TL;DR version: don't worry about the legacy "performance" drivers.  There isn't any purpose to them now.
4 条消息(共 4 条)
AllenJessup
This is the driver I'm using at the moment. It works fine. I'd suggest downloading the most recent from Nvidia. As others have mentioned. The Performance Drivers dissipated quite a while ago.
The P4000 is a very good card. It will even handle Leica Cyclone which is harder on the graphics cards than Civil 3D.
Allen Jessup
CAD Manager - Designer
0 个赞
