Civil 3D Forum
Weird surface look like
7 REPLIES 7
Message 1 of 8
emanoelufpe
601 Views, 7 Replies
do u guys have any idead what can cause that ?
Tags (1)
Labels (2)
7 REPLIES 7
Message 2 of 8
nkiakas
in reply to: emanoelufpe
HI @emanoelufpe
Looks like you have targeting (mostly elevation) issues.
Could you share you file to take a look?
Message 3 of 8
emanoelufpe
Hey @nkiakas  ofc i can share you the file. The surface named "PROJETO" is the weird surface. Im glad if u can help me
Message 4 of 8
emanoelufpe
in reply to: nkiakas
here it is forget to reply correctly
Message 5 of 8
m_kingdon
I believe the problem is in the corridor surface.  You have selected too much data for the corridor surface to work with.  Try adding "Top" only first.  If the kerbs are not being modelled correctly, try adding kerb back or flowline gutter as feature lines, not links.  My corridor surfaces are using just TOP link and Flowline_Gutter and Back_Kerb as Feature lines.
Mike Kingdon
Civil 3D Zealot
Message 6 of 8
nkiakas
Hi @emanoelufpe
Could you please share your subassembly Talude Nota De Servico Der SP 2018 (TaludeNotadeServicoDERSP)
Message 7 of 8
emanoelufpe
no idea how to share this
Message 8 of 8
emanoelufpe
(SOLVED)
i would like to first thank you everyone who tried to help me, really apreciate you efforts. but i fixed just doing modifing the target of the corners to set it to point to the profile of the aligment on the elevation field and now the 3d look now fine.
Rail Community
