wcs slightly rotated when applying coordinate systems
caruivo
caruivo
When I select a coordinate system to my dwg file, the north rotates slightly
Any idea why it rotates?
Thank you
Pointdump
Hi Carlos,
I've seen that with custom coordinate systems and sometimes when using the Transformation Tab. Can you post your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
caruivo
Hi @Pointdump,
I send you a file where I found this issue. It has associated a custom coordinate system.
Thank you
Pointdump
Carlos,
Thanks for posting your drawing.
PT-TM06/ETRS89 is a bad definition in MAPCSLIBRARY. Use instead ETRS89/PT-TM06, which matches >>>EPSG:3763 ETRS89 / Portugal TM06<<<.
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
Carlos,
To give a visual, the GeoMarker at the center of Bing Live Maps extents is normally on the Central Meridian, so would be a Convergence of zero. Wierdly, the pie-shaped extents of PT-TM06/ETRS89 are rotated.
Dave
Dave Stoll
Las Vegas, Nevada
caruivo
Well, I tried to open the same file in another computer that also use the same auto-registered coordinate system, and the rotation of the north doesn't happen.. so I deleted the auto registered coordinate system, an created it again (by opening a file with that) and it works.
I have no idea what could happened.
Thank you for your help @Pointdump
