Volume Surface Display
Dave5Y5NB
Dave5Y5NB
I'm fairly new to Civil 3D. My previous experience is with Carlson Civil. In that software, there is a routine that applies a grid of cut and fill depths as a way to double check whether the numbers you get in the volume report makes sense. Is there a similar function C3d?
Senior CAD Designer
Newkirk Engineering, Inc.
Ormond Beach, FL
Yes, right click on surfaces, create new and select a TIN volume surface.  Add your two surfaces to compare then you can display as isopachyte contours
Pointdump
Dave,
Jeff Bartels has a good way to <<<Create a Cut & Fill Earthwork Exhibit>>>.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Joe-Bouza
Just add surface labels by grid on you volume surface.
If you want red and green you need 2 label styles and an expression
Joe Bouza
