Volume report
Volume report
Volume report
Dear all,
My problem is that every time I run the volume report (from toolspace > toolbox > volume report), the CSV/html file generated gives cross section areas and volumes to 2 Decimals. I would like to change to 3 decimals. How do I do that?
When I use the procedure for modifying text properties in the volume table plotted in the model space, the decimals are modified correctly, the problem is only on the CSV /HTML file extracted.
tcorey
You need to change the precision setting in your .xsl style sheet. Here's a short video that shows how:
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Wow! How could have ever thought of this! Thanks a lot.
