volume calculation in grid base
dilsmails
dilsmails
Hi, all I want to calculate the volume of my project between two surfaces zone by zone (please see attached image).I know we can calculate the volume of this by using paste surface to new surface and clipping the required area with a boundary line. but in this way, (eg: we have 100’s of zone, then we need to create 100 duplicate surface.) if there is any other way to do it faster please help.
Thanks...
Dileep
onsionsi1
On the Civil 3D 2015 you can use a Volumes Dashboard
First things you have to get a comparison between the two surfaces the base surface is EG and a comparison surface is your surface that have all your zones.
Second thing use the buttom on the following images just click the boundry i.e for Z1 you get the volume between this zone (Z1) and the base surface (EG) and so on for next zonesVolumes Dashboard.PNG
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
Pointdump
Dileep,
I haven't used it, but there is a Parcel Volume Report that might automate your calculations.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
neilyj666
Convert the zones to parcels and create a volume surface between exsiting and proposed, then use the Parcel volume Report as advised by Dave. I use the Parcel report all the time as it is seem less tedious than using the Dashboard but you may need to reformat the output in Excel.
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
