Volume Calcs
tonykhoury
Volume Calcs
tonykhoury
hello,
Please see the attached sketch.
I have the following surfaces: "1","2","3","4",and "5"already set up in civil 3d.
What's the easiest way to calculate material M-A and M-B as shown in the sketch. I am wondering if need to setup a table in excel or there is a way to do it using Civil 3D.
As always, thank you in advance.
Tony
Replies (12)
Joe-Bouza
creating all the clips and transition surfaces would probably be more work than its worth
Joe Bouza
mathewkol
This is a pretty easy task.
http://www.civil4d.com/2010/01/surface-volumes-301/
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
neilyj666
You'd need to create sample lines and materials but it could be done
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Joe-Bouza
Hi Matt
I get most surface algebra but this one has that extra subtraction and I'm not sure I see in the blog how to account for it
Looking at material A; M-A
This appears to be all the material between surface 1 and surface 3. Yet the material must not be counted where surface 2 overlaps. I didn't get that from the blog. How is that accounted for?
The same is true for material B
Joe Bouza
mathewkol
It's all about how you set the above / below values. Specify 3 surfaces and set the aboves and belows properly. In his case, below the flat red line, above the flat blue line, and above the curvy red line.
Matt Kolberg
Joe-Bouza
interesting! I was stuck thinking I could only do two surfaces at a time.
Joe Bouza
mathewkol
You can add as many as you like. 🙂
Matt Kolberg
neilyj666
But it can get very complicated...;)
Joe-Bouza
Ya think😳
Joe Bouza
Joe-Bouza
How is that done I only see EG and Datum options
Joe Bouza
mathewkol
I assume you're using a volume criteria. You have to go I to the material properties and add rows in there yourself. I'm traveling this week, otherwise I'd make a video to show you.
Matt Kolberg
Joe-Bouza
thanks
Joe Bouza
