G'day,
How do you determined the stripping volume? (i.e. I want to strip 0.5'
of existing material from the entire site before I determine cut/fill volume
to finished grade). Right now, w/ civil 3, I used the 3D surface area in
the Extended Surface Statistics in TME.
Thanks in advance,
Jim
Win XP, SP2
1.69 GHz, 1.00 GB RAM
LDD 3 w/ Civil 3 (AutoCAD 2002)
(Upgrading soon to: 2006/ Civ 3D YEA!!)
wrote in message news:4874431@discussion.autodesk.com...
To clarify, use method 1 if you want only to query and obtain information
about a surface volume or bounded volume. Use method 2 to create a
persistent surface object. Therefore, you can display cut and fill contours,
cut and fill points, add labels to it, and add it to a project., etc.
Jonathan Burgoyne
