Volume between two surfaces - accuracy
marko.orkic
Observer Observer
marko.orkic
Observer
Observer
When calculating a volume between two surfaces I often see a difference when making a TIN volume surface then going to surface properties - statistics TAB Volume - NET volume and the total volume I get when making a surface table with the Volume in it. The difference is sometimes more than 20% which is considerable. Which one of these two ways is the more accurate way of calculating total volume?
tcorey
Yes, 20% means there's a serious issue. Can you post your drawing?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
