Civil 3D Forum
volume between proposed and existing surfaces
2 REPLIES 2
davshkl
177 Views, 2 Replies
How to calculate cut/fill volume between proposed and existing surfaces (no alignments/corridors are involved) in C3D 2023?
Thank you!
Labels (1)
2 REPLIES 2
JDB423
in reply to: davshkl
Select either one of your surfaces and select the 'volumes dashboard' icon in the ribbon, this will bring up the dashboard where you can create a new volume surface (see screenshot). From here, you can set your base surface to the existing and comparison surface to the proposed, this will create a volume surface showing the cut/fill.
You can then use this button to generate a cut/fill summary if needed.
Hope this helps!
davshkl
in reply to: JDB423
Thank you very much!  Really appreciate it!  Be well 🙂
Rail Community
