Message 1 of 16
Viewport Scale Field in View Label Block uses Xref scale for "use scale name"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
My View Label Block assigned to my SheetSet includes a Viewport Scale Field. It is almost always changed to the Xref scale even when I edit the field and set it to "use scale name". When I update the field manually it reverts to the correct scale and that stays through regens but ONLY as long as I stay in model space within the floating viewport. As soon as I change to paper space it changes back to 1:10_XREF
Sometimes I can get it to correct itself if I use SCALELISTEDIT and move the viewport scale to the top of the list but even this is only temporary. It inevitably reverts to 1:10_XREF
Does anyone know what is causing this or how to fix it?
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
8.6.52.0 AutoCAD Architecture 2024
