View frame wipeout area color
cyberflow
cyberflow
I am curious to know, is there a way to change the wipeout color from the matchlines in the viewframe ?
I noticed some drafters output it in a different color.
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
Yes. Edit the Match Line style. See Display tab, Match line mask.
samir.rezk
Autodesk Support
Autodesk Support
Hi @cyberflow
An alternative option to changing the color in the Match Line style if you are using the out of the box NCS template is to change the color of the C-ANNO-MATC-PATT layer, that's the layer being used for the Match Line pattern (the default is a solid hatch not a wipeout!)
Hope this helps,
Samir Rezk
Technical Support Specialist
