Vertically Offset a 3d Polyline
30009255
30009255
Hi, I'm looking to offset a 3D polyline vertically, is there a specific command to do this. I could edit each polyline individually but as it is a large document this would take a long time. Thanks
Home tab>Create Design panel>FeatureLine>Create Feature Line from Stepped Offset (_AeccOffsetFeature). It works on 3DPOLYs too. The offset distance is horizontal, so 0.0 for vertical.
Also, if it is truly vertical you can just copy or move the 3DPOLYs, select any point for base point, enter @0,0,Z where Z is the change in elevation. The above command allows for horizontal offset as well as vertical.
Jeew-m
Convert the 3d polyline into a feature line.
Then use the raise/lower option.
Then explode the feature line to get the 3D polyline back.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
wfberry
I don't think either one of you answered his question properly.  Use the move command and select as many as you want then give it the @0,5 to raise all  polys 5'.  (substitute proper number for 5)
Will
Joe-Bouza
MOVE 0,0,0 to 0,0,distant raised
Joe Bouza
neilyj666
MOVE > Displacement > 0,0, Z value to raise e.g. 0,0,1 to raise by 1 unit
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
dboschPQLGH
Community Visitor
Community Visitor
Man I am glad you posted this.  I cant beleive I didnt know this before. I have always done all kinds of gymnastics with offset to make this happen myself. Today was a day worth waking up for!
