Civil 3D Forum
Vertical transformation(raise all Z values)
2 REPLIES 2
jerkku_h
194 Views, 2 Replies
Hi, i am working with pipe networks for factory area and client wants final drawings with two different coordinate systems, which neither are standard systems(don't ask me why). I have no problems with X and Y transformation, because i don't need to deliver actual Civil 3D pipe network, just layout drawings. But i need to edit pipe/struct elevation values on layout drawings.
Is there a way to do vertical transformation that would change all Z values X amount? I need to raise all elevations +0.14m and i really would not want to that manually, since i have close to 400 structures and +5x as many pipes.
Labels (2)
2 REPLIES 2
neilyj666
in reply to: jerkku_h
Would the AutoCAD MOVE command work - Select all the objects, Move, Displacement, 0,0,0.14? I don't work with pipes and structures so am not familiar with the subtleties involved.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
jerkku_h
in reply to: neilyj666
Yeah this worked.. It was way too simple solution so i didn't even thought of that. I assumed I would need to do coordinate transformation since pipe network objects doesn't have Z value in same sense as normal AutoCAD objects.
Thank you for your help!
Rail Community
