Vertical Grid not Shown on Section
nizamthonichal
nizamthonichal
Please see attachment. The above section is what we have.  The below section what we want. (Attached)
I would like to add vertical grid, wherever coming in the band elevations and end of Left and Right side end. (Marked as Blue lines).   I've looked for grid interval, which I mentioned  but cannot find it in the style?
Also I would like to fix the outer boundary band width always 50cm left and Right side for the clearance. (Clouded)
Is anyone response early as possible, highly appreciated.
Nizam
NA
Karadzhaian_Eduard
@nizamthonichal
About clouded places - try to do these steps:
Eduard Karadzhaian
Senior Civil Infrastructure Engineer
Blog| LinkedIn| E-mail| Youtube|
Karadzhaian_Eduard
About blue lines - I recommend you to create a simple corridor, then set a special label style for neccesary points (using Code Set Styles). It's not so quick as earlier way
Eduard Karadzhaian
nizamthonichal
Hi Sir,
First of all thank you for the reply,  I made  a simple corridor and  create  a code set style.  But I don't know how to fix corridor labels  in Section band.
Please support me.
