Civil 3D Forum
Vertical Curve Labels on Profile
4 REPLIES 4
16557 Views, 4 Replies
I just created a profile by choosing my PVIs and linking them together with tangent curves.  How do I add labels to show the vertical curve properties (K value, curve length, station of PVI, elevation of PVI...)?  I'm guessing I have to edit the label style?  Any help is appreciated!
Thanks.
4 REPLIES 4
  1. Select your alignment
  2. Add labels
  3. Type: Geometry Points / Profile Geometry Points
  4. Add
Let me know if that works for you. Like you said, you'll most likely have to tweak the styles.
Happy drafting!
ToddRogers-WPM
It sounds as if you are not using a template file with the required label styles.  Import the the "out of the box" template file by clicking on the Manage tab and at the far right, click on Import.  Browse to C:\Users\[user name]\AppData\Local\Autodesk\C3D 20??\enu\Template and choose the _AutoCAD Civil 3D (Imperial) NCS.dwt.
After you do this,select your proposed profile, in the contextual ribbon, select Edit Profile Labels.  Once in the dialog box, at the bottom right, select Import Label Set.  Then select the Complete Label Set.  Click OK and they will show up.
Todd Rogers
marlenesadaj
I would like to label my verticial curves in my profiles as described above, however when I select my alignment and click the add lables button typing "geometry points" does nothing and there is no geometry points option in the add labels thread....I have tried editiing lable sytles in my profile but there does not seem to be anywhere to select to add this information...???
Marlene
Jay_B
in reply to: marlenesadaj
The "Profile" should be selected, not the Alignment.
Open the tutorial drawing "Profile-3A.dwg" and select a vertical curve label > right click > select edit labels.
The tutorial drawing can be found here:
<AutoCAD Civil 3D installation location>\Help\Civil Tutorials\Drawings
For example 2014 is here:
C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Help\Civil Tutorials\Drawings\Profile-3A.dwg
Reviewing the Labels here should provide some insight as there are "Geometry Points" included in profile labels.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Rail Community
