Vertical Alignment Design Table
I am looking for a way to create a table of my vertical alignment
to show pvi station, pvi erlevation, k value, HP ot LP station and HPor LP elevation,
Will appreciate your help
Jeew-m
Dear Friend,
If you need this report in excel/web file format you can use report manager.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Thanks so much for your input.
I found a way which is more like what I want to create.
Through panorama, copy and paste it to an spread sheet.
Thanks again
HR
Thanks again
HR
Hi,can you show me steps by steps that u used through panorama?
Go to the profile view
Right click, and go to edit profile geometry (see image 2)
The profile layout tool will pop up
On the pop up select profile grid view, third icon from the right (see image 2)
Panorama will pop up, right click inside and select copy all
Then, paste it on your drawing as xcel format (see image 3)
Delete the columns you do not need and you done.
Hope this will help
Hector Ruiz
