Vehicle Tracking 2019 Custom Fire Truck Help
We typically get very limited information about Fire Trucks in our area that match up with all the setting in Vehicle Tracking. Below is an example of the information provided to me.
When going to the manufacture website, i can get more data, but it's not labeled the same as some most of the settings in Vehicle Tracking. I'll admit, it's must easier to use the software then AutoTURN however, custom properties on vehicles not already in the library is not very intuitive. Anyone else have better ways of making a custom vehicle?
Pierce Quantum 95' Aerial Mid-mount Platform:
Overall Length - 48'6"
Axle Track - 82.92 in.
Wheel Base - 270.25 in.
Chassis Overhang - 82.44 in.
BrianHailey
If the department already has a similar truck, go to their station with a tape and a notepad.
Go through the process of creating a custom vehicle in Vehicle Tracking and not down all the measurements you need and use that as you measure the existing truck.
Or sketch something up and send it to the manufacturer asking for that specific information so you know if that particular truck will meet the conditions needed prior to purchasing it (they'll jump through hoops most likely if they think they'll lose a sale).
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
copper.chadwick
Autodesk Support
Autodesk Support
@Anonymous,
Really great question presenting a fantastic opportunity to demonstrate two things. One being the open dialogue between manufacturers and the second being the creation of custom vehicles within Vehicle Tracking.
@BrianHailey is correct, approaching the manufacturer is paramount to getting exact dimensions, barring going down to the fire station to measure the Pierce Model.
Personal Note & not to be confused with implied design specifics: Something to consider (a close friend designs fire trucks for a company based out of Idaho oddly enough) is that most of the times the chassis are custom built to the specifications of the Fire Department (See CAL FIRE - Fire Engines site for some great leading standards) by Pierce on modular frames with matching engines and transmissions; built by GM, Ford, Freightliner etc. So if there is hesitation on that access either locally with your fire department or remotely from pierce, you may be able to cross reference the axle locations and wheel stop-stop angles from those truck manufacturers.
The next great opportunity is to simply answer your question. If you are already in Vehicle Tracking -> Vehicle Library Explorer -> Vehicle Wizard that is the best way to create a custom vehicle at this time.
The only other work flow would be to import or transfer Custom Vehicle Libraries from AutoTrack into Autodesk Vehicle Tracking as described below.
Issue:
You have created your own vehicle libraries to hold amended or customised models of vehicles in AutoTrack and would like to use them in Autodesk Vehicle Tracking.
Solution:
Both Savoy Computing's AutoTrack and Autodesk Vehicle Tracking use library files (xxxx.atl) to hold vehicle models that are used for tracking.
If you wish to transfer vehicles from your legacy Savoy Computing's AutoTrack software to Autodesk Vehicle Tracking, you will need to:
1. Create and save your Savoy Computing AutoTrack custom vehicle library to a location that you can access from your Autodesk Vehicle Tracking installation.
2. Within Autodesk Vehicle Tracking, open the Vehicle Library Explorer.
Vehicle Library
3. From the File menu, select Open Library. You can then work with the vehicles from that library.
Best of luck let us know how it goes!
Please hit the Accept as Solution button if a post fully solves the issue or answers the question.​ Thank you for your participation, your accepting a solution adds value to the post for the community as a whole, and helps other members find answers to their issues.
Copper Chadwick
Designated Support Specialist
@copper.chadwick and @BrianHailey
Thank you both for your input. It helps. It just always seems like there's additional information that needs to be provided that I can't begin to understand without some sort of design information on these trucks that go beyond the basics. I'm probably over thinking it most of the time.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
