Civil 3D Forum
VBA to add an arrow
3 REPLIES 3
1254 Views, 3 Replies
VBA to add an arrow
Hi everyone,
I am a new one to learn how to use vba to draw autocad.
While I am drawing the sewer, I use "addLeader" to add arrow to show the direction of wastewater.
But I find that it shows the line without arrow.
Here is my codes:
Sub sewerdraw()
Dim arrow(609, 22) As Variant
Dim parrow(0 To 5) As Double
Dim leadertype As Integer
Dim leaderobj As AcadLeader
Dim annoation As AcadObject
Dim arrowlayer As AcadLayer
For i = 1 To 609
arrow(i, 2) = Cells(i + 2, 19) 'endpoint x axis
arrow(i, 3) = Cells(i + 2, 20) 'endpoint y axis
arrow(i, 4) = Cells(i + 2, 21) 'startpoint x axis
arrow(i, 5) = Cells(i + 2, 22) 'startpoint y axis
parrow(0) = arrow(i, 4): parrow(1) = arrow(i, 5)
parrow(3) = arrow(i, 2): parrow(4) = arrow(i, 3)
Set arrowlayer = ThisDrawing.Layers.Add("sewer direction")
arrowlayer.color = acCyan
leadertypt = acLineWithArrow
Set annoation = Nothing
If arrow(i, 2) = "" Or arrow(i, 4) = "" Then
Else
Set leaderobj = ThisDrawing.ModelSpace.AddLeader(parrow, annoation, leadertype)
leaderobj.Layer = "sewer direction"
ZoomAll
Next
End sub
The x and y values are Two degree zone transverse mercator projection, something like :
startpoint(196048.835,2508903.016); endpoint(196053.832,2508818073)
Could anyone tell me why there are no arrow, please?
3 REPLIES 3
MikeEvansUK
I do not understand why you want to do this in this way, I think you're making life too hard for yourself.
If you are using Civil3d pipes try adding a leader to a label, if you are specifically using a Line or Polyline try using a modified linetype to include an arrow or > text inside.
You will only need to draw / convert the lines such that they are going downhill. (pedit > reverse or Mirror cmds)
You can easily create custom linetypes with the express tools.
I use this method for my pipework in civil3d and always draw pipes downhill but I also use an label arrow aligned to the slope as a check Expression for rotation is " if ({Pipe Slope}>0,0,pi) "
Mike
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
in reply to: MikeEvansUK
Thanks for reply.
I will use this way to draw my picture because after filed survery I got hundreds even thousands of data. I want to let the program to draw those pictures automaticlly. That is why I need to use VBA program to help me.
Kuang
MikeEvansUK
I would use a block instead of a leader and insert it at the midpoint. Head to the customisation forum.
Dim BLOCKOBJ As AcadBlockReference
BLOCKOBJ = g_oacadDoc.ModelSpace.InsertBlock(varIntPt, VisiBlock, 1.0#, 1.0#, 1.0#, 0)
Function InsertBlock(InsertionPoint As Object, Name As String, Xscale As Double, Yscale As Double, Zscale As Double, Rotation As Double, Optional Password As Object = Nothing) As Autodesk.AutoCAD.Interop.Common.AcadBlockReference
Mike Evans
Rail Community
