Varying offset from Feature
654work
Message 1 of 24
654work
We need to grade from top of bank to the flowline of a ditch at a 3:1 slope.  The flowline will very in slope and we know the elevations at specific intervals along the flowline.  I thought C3D had a grading tool that would grade down to user input elevations along the feature line.  Hopefully the attached will clarify what we are looking for.  The goal is to have a feature line at the flowline.
C3D 2022
Replies (23)
Message 2 of 24
brian.strandberg
I would start with the grading tools. You can create a grading criteria very easily to grade to surface at 3:1
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 3 of 24
654work
@brian.strandberg, thank you for the reply.  we do not want to grade to a surface, but create a second feature line.  The distance the new feature line is away form the original feature line will vary, based on the elevation target.  I can calc this by hand, but thought civil 3d had a way do automate this.
Message 4 of 24
Joe-Bouza
If the top of bank is known and the the flow line is known there is no grading to be done, just add the two FL to the surface.
Joe Bouza
Message 5 of 24
Joe-Bouza
Are you looking to locate the Flow line?
Joe Bouza
Message 6 of 24
Joe-Bouza
If the line are fixed the project 3:1 a distance beyond the Flow line the extract the 3:1 surface elevations to the flow line.
This may differ then your Known elevations.
Maybe you are trying to locate the flow line ? if this is the case
grade to each known elevation AT 3: 1  , Then add transition in between, since they are 3: 1 the transition will and your FL will be located
Almost forgot. to do this you answer NO  when asked to apply to entire FL
Joe Bouza
Message 7 of 24
654work
@Joe-Bouza, I don't think I have explained this well.  Hopefully this will clear it up some.  The top of bank is known and specific elevations along the flow line are known, the slope of the the channel varies.  We can calc the location of the flow line through curves down from the bank, but hoped C3D would generate this for us instead.  If the top of bank was a straight line, projecting to the flow line could be quickly done, but the channel is several miles long and meanders back and forth.  Also as the hydraulic model is updated, the elevations may change.
Message 8 of 24
654work
How do you add the transitions?  That is the part I'm missing.
Message 9 of 24
Joe-Bouza
this is the part I dont get. If you know the elevation of the channel and the top of bank is fixed, the slope is what it is
anyway, the green lines are the known channel ele at 3:1, the yellow is the fixed top of bank FL. after you place the grading slivers, then in the grading tool bar drop down pick transition and pick the top of bank FL between the slivers
Joe Bouza
Message 10 of 24
Joe-Bouza
Is the flow line in a constant position?
Joe Bouza
Message 11 of 24
brian.strandberg
If you can share the drawing that will probably help a ton.  Thanks.
Message 12 of 24
Jeew-m
If I understand you correctly this is what I do.
1. Import your flow line points through a point file and add it to a point group. (If you can use dynamo that would be great)
2. Offsett your flow line polyline either side (say 1m)
3. Convert the two lines to feature lines at an elevation you like. These are dummy feature for our work.
4. Create a surface and add the two FL as breaklines
5. Then add the point group to the surface. Now you will have the flowline elevations on the surface
6. Convert the flow line polyline to a feature line. Get the elevations from the surface but avoid adding elevation points at intermediate break points and set relative elevation to 0.
7. Now when the elevations of the flow line change as a result of hydrological reasons, remove old points and add the new points to the same point group. If the changes are minimal you can manually update the points.
8. This will update the surface and ultimately the flow line feature line because it has relative elevations to the surface.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 13 of 24
chriscowgill7373
Based on your description, you want to grade to a feature that has a varying offset and elevation.  This, unfortunately, (or fortunately, depending on how you feel about grading objects) cannot be done with a grading object.  You can do it with a corridor, using an assembly that uses the link slope to elevation generic link.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 14 of 24
654work
@chriscowgill7373, please correct me if I'm wrong, but the linkslopetoelevation subassembly will not create the flowline.  We would need to hand calculate the flowline and create a featureline, the set the target for the subassembly.
Message 15 of 24
654work
@Jeew-m, I may be missing something from your suggestion.  The flowlines horizontal location is not know, without doing hand calculations through the bends.  The flowline horizontal location is what we are trying to automate creation of.  With the horizontal location, the surface would be quick to create.  The way I understand your suggestion is I would need to start with the flowline, then create the surface based on the points and the horizontal location of the flowline.  If I'm missing something from your suggestion, please let me know.
Message 16 of 24
654work
@Joe-Bouza, no the flowline bends horizontally in several places.  The top of bank varies in elevation too.
Message 17 of 24
654work
@brian.strandberg, I will try to remove certain information from the file and share, but not certain I will be able to.  This is not my project, someone else in the office is working on it and we are trying to come up with a solution.
Message 18 of 24
Joe-Bouza
Pardon, that wasn't what I meant.
If you are looking to locate it, then there is a bit more to do.
Make a temp grading and surface from the top of bank., set the tessellation to something reasonable, and grade at slope for arbitrary length beyond where the flow line is expected.
the feature line for the flowline is initially placed with the known elevation snapped to the the tessellation ray. have a Feature line label style that displays vertex and slope. each vertex coincides with a ray. anywhere along the ray is 3:1 , grip edit the unknowns to a ray until the flowline slope is satisfied.
Not perfect but you will get what you need in relatively short order
Joe Bouza
Message 19 of 24
654work
@Joe-Bouza, I tried the transition with two elevations and 3:1 slope, but it does not produce the grading object.
Message 20 of 24
654work
@Joe-Bouza, ok, I get what you are saying
