utility crossing table
Joe-Bouza
Joe-Bouza
we have to prepare a utility crossing table for our Sanitary FM design that crosses existing utilities
 The table has the form
#, utility name, top of utility, bottom of utility, top of FM, bottom of FM, clear distance
I did this with pipe networks and surfaces
I used a null structure at each utility crossing the FM and can easily populate # , utility name,top, and bottom of utility. I couldn't use a reference text for the FM so I made a surface of the invert and an expression for the pipe height, assigned the surface to the nulls and populated that as top, and bottom of FM
How can I get the vertical separation from the FM to the Utility? I will entertain a work flow change, and would prefer not using an add-on that I don't have
Joe Bouza
Replies (11)
Dexterel
long shout. I so a app on Autodesk app store that label crossing pipes like you need. I don't know what are the app capabilities to make tables. Worth giving a search on app store.
Joe-Bouza
I have that one. Alas, no table
Joe Bouza
can you export the pipe data to excel?
there you can write an equation to calculate the clearance
and datalink back to cad . . ..
just a thought
qnologi
I don't know if this what you're talking about, but I create "Pipe Clearance Tables" using Excel, then insert it using "Table", as a datalink.
I've attached somewhat of a unfinished "crude" example.
qnologi
qnologi
My company won't allow anyone to connect to the Exchange, so I guess I need to ask...
This "App" of which you speak...
I was wondering if they are able to store "ALL" pipe dimensions and specifications within its database to do an accurate assessment of for a utility crossing?
Or, is it up to the user to input such info. prior to use?
qnologi
Joe-Bouza
thats an option.
Joe Bouza
Joe-Bouza
The app I know of has no data base. It computes on the fly by selection and provides static text
Joe Bouza
Joe-Bouza
That is what Im doing but would like to use a c3d table
Joe Bouza
qnologi
Thought you might find this interesting... Smiley Wink
http://forums.autodesk.com/t5/autocad-civil-3d-ideas/idb-p/31/tab/most-recent
Regarding "Utility Crossings"
qnologi
Joe-Bouza
Got my vote
Joe Bouza
Add my vote to that item, too!!!
thank you
