Using VB Script for aditional data to Property Set
buinhuthuong
buinhuthuong
Hi there,
I  am using VB Script in Formula Property Definition to add more data for an object.
As the image below, I could get some information such as Inner Structure Width, Inner Structure Length, and Structure Height with these codes.
I would like to get more information in Table 1 such as Wall Thickness, Floor Thickness.
How can I get it by editing my command code?
These are the command codes that I used in the project.
RESULT="--"
On Error Resume Next
Set oApp=GetObject(, "AutoCAD.Application")
Set oCivilApp=oApp.GetInterfaceObject("AeccXUiLand.AeccApplication.13.6")
Set obj=oCivilApp.ActiveDocument.ObjectIDToObject([ObjectID])
If obj.BoundingShape = 1 Then
Result = CStr(obj.StructureInnerDiameterOrWidth*1000)
Else
Result = Cstr(obj.StructureInnerLength*1000) + " x " + CStr(obj.StructureInnerDiameterOrWidth*1000)
Thank you for your attention and have a good day.
MikeEvansUK
Use the find by context to get data not explicitly exposed.
See below example for material.
RESULT=obj.PartDataRecord.FindByContext("Material_Type").Tag
Mike
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
buinhuthuong
Hi Mike,
Thanks for your answer,
I am still using your command code, but it has not worked.
I am a newbie working with VB Script.
For this reason,
If possible, would you please give some specific explanation?
My goal is how can I bring data in this table to Property Set.
I appreciate it, Mike
buinhuthuong
Have anyone would help me? 😶🙄
Have a good day all of you,
rl_jackson
I believe what @MikeEvansUK was saying that between the "" is the variable you want exposed to the property set.
HTH
Rick Jackson
Survey CAD Technician VI
buinhuthuong
 @rl_jackson @MikeEvansUK , amazing,
Thank you all for your useful solution.
I appreciate it,
Type a product name
