Point table with comparison benchmark elevation.
I am working on a project that uses a Lidar surface for elevation information. We believe that the Lidar surface elevations may be off by .05-.15', in comparison to a surface shot with a total station. The surveyor will shoot construction staking with the total station. I would like to use known benchmark points to create a cut/fill elevation situations for construction staking. I need to generate a point table that will list the known benchmark and list cut/fill elevations for the stakeout points. The initial design points are tied to the Lidar surface.
Examples: BM=100.00
Point 200: FL (lidar)=100.15
Elevation difference vs benchmark=0.15'
BM=100.00
Point 201: FL (lidar)=99.90'
Elevation difference vs benchmark= -.10'
I would like to display the BM elevation in the table just once, list the elevation difference in a column, and the adjusted elevation in another column.
Table format: Point Number|Northing|Easting|Elevation|Description|Elevation Difference|Adjusted Elevation
How to create the elevation difference and adjusted elevation columns? Any ideas?
Rick Spangenberger
