Civil 3D Forum
Using Profile View and Pipes for a 'Services' Section
1 REPLY 1
280 Views, 1 Reply
Hi All,
I am trying to develop a profile view Object Style that will show the following information:
- Natural Surface;
- all types of services (comms, power, stormwater, sewer, etc);
- proposed building levels below ground (basement 2, basement 1, ground floor, etc);
- building ground anchors.
I am currently showing the above information as pipes (e.g. I have placed each basement on plan as a 'pipe' with the diameter as the slab thickness), this displays well on the section but my issues begin when trying to organise the data bands.
I would like to develop the following data bands:
- Surface level (complete - no action required here);
- service invert level (invert of each service crossing shown on one data band);
- clearance to ground anchor (this could be tricky as the clearance from ground anchor would need to be interpolated);
Before I delve into the above I want to see if it is even possible. are the profile views flexible enough that I could set it up to produce clearances between services?
Is there a better/easier way to model existing site services?
Thanks in advance for your help
1 REPLY 1
tcorey
Have you considered using PROJECTOBJECTSTOPROF command instead of Pipes?
As far as putting the data in a Data Band, I don't think so. When you projects the objects to the Profile View, there will be a labeling option, but it won't be part of an actual Data Band. Maybe that can work for you.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
