Are you simply wanting to grade the site or are you looking to have subassemblies to see materials in section.
In a nutshell all you need is alignments/ profiles and or feature line for you linear objects. Add as baselines.
I would hazard against trying to use assemblies for tight geometry. I double you can get a subassembly for every piece of material
But not to dissuade, the corridor is very stable. I use FL as baseline and attach a MP sub to run in the corridor definition. up might get some curs and sidewalks but again sharp turn can be a bear.
I do it similar to FL grading only I add the FL to the corridor as a baseline instead of adding to surface
Joe Bouza
