Civil 3D Forum
Updating parameter for multiple pipe network objects in properties vistas
3 REPLIES 3
manibhleria14
359 Views, 3 Replies
Hi
I have a pipe network laid out to depict existing underground services. Accuracy in depth does not matter much but to the extent that they are shown in the long sections.
The problem i have at the moment is, most of the pipe inverts are around 0m elevation whereas the surface elevation is around 350m. Ideally i want to be able to select all the pipes in the properties vistas and specify start and end cover depths for them. Is it possible by any chance?
The only other way that i know is to manually type in start and end invert levels. Looking at the number of pipes, i do not want to do this painful task.
Maninder
3 REPLIES 3
KirkWM
in reply to: manibhleria14
I think you can select all the related pipes, using selectsimilar command, them edit the attribute in the properties panel. Hope this helps.
Joe-Bouza
Have a cover rule. select pipe amd apply rules
Joe Bouza
lynn_zhang
Hi @manibhleria14
Just checking to see if your problem has been solved. Have you tried the suggestions from our experts above and did they work? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
Rail Community
