Civil 3D Forum
Unknown symbol
4 REPLIES 4
709 Views, 4 Replies
Unknown symbol
What is this symbol I get connected to my corridors anh how to remove it?
Zoom E makes it cover my screen!
4 REPLIES 4
Kevin.Spear
Hi, what you describe sounds like either the alignment warning symbol or a point style with marker set to "relative to screen" or a structure symbol also set relative to screen. If it's the alignment, then you can disable those warnings, it its the point or structure symbol, use a different style or edit the style to not be relative.
hard to say which it might be without seeing the drawing. Any way you could post it?
Hope this helps!
Kevin
Kevin Spear, PE
jroot
Try unchecking the Diagnostic Messages and Solution Tips in Options:
tmachado
Hi @Anonymous, if you can select the object do a LIST of it so you what it is, this only shows when you do a zoom extend, it could be some missing xref or broken data shortcut
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
in reply to: tmachado
This is a corridor what I know.
If I change the Code Set Style to something like "No Show" it just pops up!
I have not really figure it out but there are so many reasons for this to show up...
I am still looking...
Thanks anyway!
Rail Community
