Unable to paste multiple surfaces into single surface.
rupesh_mahajan
Message 1 of 10
rupesh_mahajan
I want to combine various surfaces which are created by using clip boundary option in CIVIL 3D. The outer boundary of surfaces is neither connected  nor intersecting with each other. Also there is difference in elevation between respective surfaces.  If I create new surface and try to paste all the surfaces into it.  Civil 3D  fails to run the operation and gives me prompt such as error while performing operation. Please suggest any solution.
Replies (9)
Message 2 of 10
civilman1957
Have you run an audit on the drawing?
Cad Manager/Senior Engineering Technician
Autodesk Certified Professional
Intel(R) Core (TM) i7-7700 CPU
3.60 GHz/24 GB BEAST
Civil 3D 2013/2014/2017/2018/2020
Message 3 of 10
rupesh_mahajan
Yes
Message 4 of 10
rupesh_mahajan
yes
Message 5 of 10
A very common mistake, I recommend pasting them in batches, not all at once. And secondly, in the surface definition properties you can check whether you have any exclamation points.
If you encounter this error, I also recommend trying to change the pasting order in the surface definition.
Jarek
Message 6 of 10
Joe-Bouza
You may have common x,y with different z value.
You can test this by extracting boundary B offset a small amount to the outside, use as hide in A, paste in B. if it works that's the issue
Joe Bouza
Message 7 of 10
rupesh_mahajan
I have tried this solution, unfortunately it didn't worked.
Message 8 of 10
If you don't mind, you could maybe share the file, it will be easier to take a closer look.
Message 9 of 10
doni49
Try pasting them ONE AT A TIME.  See what happens.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 10 of 10
rupesh_mahajan
I got the solution for problem.
First, I will explain problem in detail.
I wanted to separate the multiple small surfaces from one major surface. After that I wanted to combine those small separated surfaces into different surface.
Solution:
First import another copy of main surface using landxmlin command.
Then use add boundary>outer command to separate  one small surface from main surface.
Then use add boundary>show command on same surface to show the other small surfaces.
Now all these small parts will be visible in 1 single surface no need to use paste surface option.
