Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
My drawing has a surface created from an xml file, and I deleted the xml file. Now I cannot delete the surface. When I look at it in Prospector, there's no option to delete, only Repair broken reference, Zoom to, Pan to, and Refresh (see attached image).
Selecting Repair broken reference does nothing that I can see, and does not fix the surface nor give me an option to select it or delete it.
I was going to try the trick to add a featureline to the surface definition in order to add entities to it to make it selectable, but there's no Edit option available in Prospector.
How do I delete this rogue surface?
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
