Civil 3D Forum
Twinmotion and Civil 3D
26 REPLIES 26
Message 1 of 27
neilyj666
2555 Views, 26 Replies
Whilst Twinmotion seems to be included with Revit, is there a similar workflow for Civil 3D/Infraworks?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Labels (1)
26 REPLIES 26
Message 2 of 27
in reply to: neilyj666
as far as what?
Message 3 of 27
neilyj666
@Anonymous in terms of there being a download in my Adesk account for the AEC Collection
Message 4 of 27
DarrenP
Are you saying you do not see Infraworks in your Autodesk Account?
DarrenP
Message 5 of 27
neilyj666
in reply to: DarrenP
Not sure why you had marked this as a solution...???
There is no issue with Infraworks appearing in my account and my query is where is the Twinmotion download as there is a Twinmotion for Revit download in my account but not for anything else in the AEC collection.
Message 6 of 27
DarrenP
There is only this one
There is no separate one for the collection
DarrenP
Message 7 of 27
neilyj666
...which brings us back to my first post - how can I use Civil 3D/Infraworks content in Twinmotion?
Message 8 of 27
DarrenP
you will probably have to go through Infraworks to Twinmotion since Infraworks can export out to FBX
Twinmotion can't open dwg files
I'll tag @ToddRogers-WPM for his input
DarrenP
Message 9 of 27
ToddRogers-WPM
Twinmotion is downloaded from the Epic Games website. It's free for standalone Revit and the AEC Collection.  Use your Autodesk login to create an account with Epic Games and it will activate it. Yes, fbx is the way from Infraworks to Twinmotion.
Todd Rogers
Message 10 of 27
m_kingdon
I've been playing with Twinmotion quite a bit recently, very interesting software that has a lot of what has been missing from Infraworks.
Ideally you want to build your Infraworks model to be as close to the final render as you can make it.
Add in your surface, all your textures as cover areas (either with closed polylines or as a corridor with your corridor model is very smooth and has the codeset with materials).  Also add in your architect model via an IFC file in my case.
Then, Present > Export to 3D Model File.  I prefer using the multiple file option over a single file, it only export 4 files anyway.  The FBX file format seems to work fine.
Then in Twinmotion, using Import, Geometry.  I find Collapse by Material to work the best.  The Twinmotion tools are quite easy to use.  Let us know if you have any more questions.
Mike Kingdon
Civil 3D Zealot
Message 11 of 27
neilyj666
in reply to: m_kingdon
@m_kingdon what did you install from the Epic Games site?
All I'm seeing is the free unlimited-time trial version which is not for commercial use
Message 12 of 27
ToddRogers-WPM
If you have the AEC Collection, and you logged in with your Autodesk login, then it shouldn't be saying Trial. It says if you are not seeing the right version, click on one of tabs and then back on Twinmotion tab to refresh it. Did you try that?
Todd Rogers
Message 13 of 27
ToddRogers-WPM
Make sure you have the other selections in the pull down...
Todd Rogers
Message 14 of 27
ToddRogers-WPM
@m_kingdon I prefer using Keep Hierarchy. I think you will find it more beneficial with InfraWorks models.
Todd Rogers
Message 15 of 27
neilyj666
in reply to: ToddRogers-WPM
Strange...I only have the Trial versions in the drop down - I'll try an uninstall and reinstall
Message 16 of 27
neilyj666
@ToddRogers-WPM @m_kingdon @DarrenP @Anonymous
The supplied Twinmotion for Revit can be run as a standalone and there is no need to download anything else from the Epic Games website. Response I had from my query below
"....Thank you for contacting us. Please know that only "Twinmotion for Revit" will be available through your Autodesk subscription; the Autodesk subscription will not include access to the commercial versions of Twinmotion that are provided through the Epic Games launcher.
Though the Twinmotion Cloud is not currently included in Twinmotion for Revit, Twinmotion for Revit will otherwise be identical to the commercial versions available through the Epic launcher. Please let me know if I am misunderstanding your question, though in terms of compatibility, Twinmotion for Revit will have the same import capabilities as the launcher's version of Twinmotion, so you should be able to use Twinmotion for Revit alongside other Autodesk products apart from Revit, such as 3ds Max.
Twinmotion for Revit can be downloaded through the Autodesk All products and Services page here if you do not have this already. Please see our FAQ here for more information: Twinmotion for Revit FAQ..."
Message 17 of 27
DarrenP
at this point i'm not sure what your needing help with anymore
i thought i answered on the install part then you asked about workflow with Civil 3D/Infraworks & Twinmotion
DarrenP
Message 18 of 27
ToddRogers-WPM
@neilyj666 totally contradicts the below...
Todd Rogers
Message 19 of 27
neilyj666
I was trying to clarify what was required to use other Civil/Infraworks with Twinmotion as the branding "Twinmotion For Revit" suggests it is for Revit only whereas it ("Twinmotion For Revit") can actually also be used as a standalone product and used to import fbx files (as you have pointed out) thus my query has been answered...😊
Message 20 of 27
neilyj666
@ToddRogers-WPM In what way is this a contradiction? The name "Twinmotion For Revit" is a bit confusing as it suggests it is exclusively for use with Revit whereas it can be used to import fbx files with more or less the same functionality - apart from Cloud which I have no interest in anyway.
Rail Community
