Is there a way to create civil 3d lines or polylines out of a GIS layer? I am working with a county parcel right now and the file is too big...I've tried to explode them so that I can delete what I do not need but that does not work. Does anyone know now to take the GIS layer and bring it into civil as regular lines?
Solved by Jeew-m. Go to Solution.
Hi @Anonymous, sure is you will need to use this command MAPEXPORT, select the location and file formats like SHP or SDF.
here is the link to the helpfile just in case:
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
Dear Friend,
I am not a expert in shape files. But by googling I found these two suggestions.
Note: These are for map 3d. But as I know map 3d commands can also be run in C3D in planning and analysis workspace.
Joe Bouza
Hi Joe,
Thanks for the information.
Hi Jeewana, these links don't appear to work. They both take me to the front page of another forum, rather than linking directly to the information. Also, I'm only able to see the first few word because both links cut the text short with a "..." Would you mind just posting the instructions directly into this forum?
