Trying to Plot TIF XREF in Monochrome
Ntuthuko.
Message 1 of 10
Ntuthuko.
Good Day
Can someone please assist me with how to set a colour TIF xref to plot in monochrome or black and white? I tried editing it on Paint but Paint cannot open the file type.
All assistance is appreciated.
Ntuthuko
Replies (9)
Message 2 of 10
AllenJessup
Do you  Use Color-Dependent Plot Styles or Use Named Plot Styles.
Allen Jessup
CAD Manager - Designer
Message 3 of 10
Ntuthuko.
I Allen
I use colour dependent plot styles.
Ntuthuko
Message 4 of 10
AllenJessup
It doesn't look like it can be affected by the plot style. Try looking in the plotter configuration for somewhere to set it to Black and White. When I did that the preview still showed color but the plot was in B&W.
Allen Jessup
Message 5 of 10
ChrisRS
I think you will need to edit the TIF file, or a copy of it.
If you are using Civil 3D, you have Raster Design available. You can change to monochrome and adjust pixel density.
If you do not have Raster Design, or you want more control, use a third party editor.
IrfanView is a good free utility that will let you edit graphics files. You can change color depth, change to monochrome, change resolution, crop, etc.
Edited files with appropriate color depth/monochrome and resolution settings will be smaller as well.
I see benefit for a 1200 dpi image if you will be printing at 300 or 600 dpi.
Christopher Stevens
Message 6 of 10
AllenJessup
I have both and Irfanview is a good program. If the OP doesn't have a raster editor and can't download Irfanview. The method I described did work on a test plot to PDF.
Allen Jessup
Message 7 of 10
ChrisRS
Thanks, Allen. I misread your previous reply that even though the preview was color the pdf was monochrome.
Good information. I am a big fan of solutions that do not require third party software.
Christopher Stevens
Message 8 of 10
BushW
Hello @Ntuthuko.
I'm just checking in to see if you need more help with this. Did the replies of @AllenJessup and @ChrisRS provided work for you?
If so, please hit the ‘Accept as Solution’ button if/when relevant so, that others can more easily benefit from the information and thank you for doing so.
Best Regards,
Wendell
Wendell Bush
Civil Infrastructure Technical Support Specialist
Message 9 of 10
Ntuthuko.
Hi @BushW
No, none of the proposed solutions worked. I eventually discovered by trial the option of editing the TIFF with AutoCAD's Raster options. In the Raster Tools tab I expanded the Process Image menu and selected Histogram, which launched AutoCAD Raster. I then selected the image. On the window that pops up there's a tab, I think, with the option of making the selected image black and white. That did it.
Ntuthuko
Message 10 of 10
BushW
Hello @Ntuthuko.
I am happy to hear that! If you ever have any problems in the future, I'll be here, and I'm glad to help.
Best Regards,
Wendell
Wendell Bush
