Hi folks,
Got another question for you. I'm trying to learn how to use parcels to do lot layouts for developments my company is going to create. As I'm the only one in the office to know anything about parcels, I have no one to turn to for help when the command goes south! So, I'm asking you guys. Here's the issue: why does the command work sometimes and not other times? Attached is a test drawing I created and defined the site, defined alignments, created the ROW using the parcel command - and then had to add the cul-de-sac - not an easy act, mind you, I offset the ROW lines to set the rear lot lines, and then I used the "Parcel Creation Tools" to make lots. Now, it worked fine going up the minor road and around the cul-de-sac, but when I try to do lots along the east side of the center road, I get the old "No Solutions" error message! Why? It doesn't make any sense. I put in the data:
Area is 5,500 S.F., Min. Frontage is 50', use frontage is "yes", offset is 25', minimum width is 50', min. depth I set at 100' (the lots are 110', but I seem to get more errors when I use the exact figure, even though the rear lot line is established! Again, go figure), max. depth I leave at 500', and I leave the auto mode off. So, why does it work on one road and not the other? Can anyone help me on this? I can't figure out what is so blessed different between these two roads!
