- Mute
- Permalink
- Report
I am facing a challenge of producing Split levels at different elevation of a building constructed on an uphill.
I want producing a Standardized Civil Engineering Plan View Section on a Platform with Civil 3D, The challenge i am facing is flattening each level of the platform to the same elevation whilst from the outside boundary clearly shows changes in ground elevation. Below is how i have gone so far about it and attached aside is the ideal representation similarly to what i must reproduce in Civil 3D, what necessary steps must i take to create the platform/split levels with different elevation.
In my approach i created a surface from a CSV file, inserted the residential boundary perimeter where the structure will be built. i created feature lines representing each split level of the platform level 52, 53.5 and 54.5 from low ground to high ground respectively. I looked forward to produce a plan view of the platform which is my first objective and also to calculate works earth volumes of cut and fills for each platform. I am using AutoCAD 2018
