Trouble labeling contours in connected shapefile when viewport UCS is rotated
- Mute
- Permalink
- Report
Hi all,
I have linked a contour shapefile to my CAD drawing and am trying to use the labeling feature in the Planning and Analysis Map Task Pane.
In the past, I have been able to generate the labels I would like to see (elevations labeled at regular intervals along each contour), and they have plotted exactly as they display in paperspace. This is not the case with my latest attempt, and here's why (i think):
In order to maximize my area coverage per sheet (and minimze the number of sheets i need) I've rotated the UCS roughly 45 degrees so that my streets run in the xy direction (more or less) in my plot sheet.
For some reason, this rotation wreaks havoc on the shapefile label programming, and as a result. NONE of the labels print. See the two prints below to clarify:
If anyone has any insight on why this might be happening, or more importantly, how to resolve this issue, it would be greatly appreciated.
