12:40 PM
I have created a network of pipe trenches and some of them är coneccting to chambers.
So I need to punch a hole in the walls and even trim off the pipe trench against that wall.
There are som trenches touching the chambers at the sida and I have to trim off those walls against each other.
I ran minimum distance beetween two surfaces and got the 3D polylines.
I tried surface boundary but did not get the result I hoped for! It works for the chambers wall with "Hide" but not with the pipe trench the way boundary works!
Any suggestions how it is possiable to trim two surfacese against each other as int the pic??
