- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Goo day,
I have created a surface using two feature lines which was offset on either side of my pipeline. Now I want to trim my surface boundary so that it follows the two feature lines. To ensure it is neat and accurate when I plot my profile view.
I tried to select the surface and then select "extract from surface' then "extract objects" then I moved the grips to neaten it up, but when I rebuild the surface it still looks the same. Not sure what I'm doing wrong.
Another question: I do not have a drawing template - I just started the drawing with the default template. I also did not setup my pipe parts list from the start. Will I be able to add custom title block to the sheets and will I be able to change the pipe material and parts later in my project? Sorry I am relatively new to Civil 3D and learning as I go along.
Thank you in advance
A
