Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
C3D 2019
extendLately my Trim and Extend commands are not working properly
I can not Trim or Extend poly lines
my system variables are set to the following.
Edgemode is set to 1
Projmode is set to 2
I have verified that the lines are on the same plan so that is not the issue. If I explode the ployline then the command works properly.
Hi @Anonymous ,
It will be easier for us to help if you can share the sample drawing that have the problem. We can only guess / assume on what is wrong with it.
Based on your observation extending polyline won't work but exploding it and extending will work. This looks like your polyline have an extra point or line inside it with zero length. I tried to replicate your problem and use the same system variable you describe but it is trimming and extending as expected. The only way I can see that it will not extend if I am extending a line 1-2 that is connected to 2-3 with zero length and I will need to do overkill to remove the extra point in the polyline for it to extend. Can you check if this is what is happening in your case? If not please share a sample dwg and that will be easier to debug.
See animated gif testing below:
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
