Hi All,
I have surface made up of a number of surfaces pasted into it. I have put masks around my surface boundary but when I render I get these triangles appearing. Some of the surface appear with the correct render IE grass and some of it appears with red triangles as per the attached file.
Any ideas?
Regards
Rich
Hi All,
Any ideas?
Regards
Rich
Maybe the problem is that you have a surface with no material selected (the red one) try to set this surface in a invisible style, but make sure that the style is invisible in all distuations, plan, section e model
