tree Mvblock not appearing in section view correctly
richardKTHG4
richardKTHG4
Hi All,
I am trying to put a MVblock tree onto a section view by going section view/project objects to section view. When I do this the tree appears on the section view but in plan view.
Any idea how I get it to appear in section please?
Regards
Rich
tcorey
Hi Rich,
The problem is most likely to be solved by editing the projection style:
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
richardKTHG4
Hi Tim,
It still does not show on the section. Is there a way I can PM you the file?
Regards
Rich
tcorey
Hi Rich,
Sure. Send it to support at deltaengineeringsystems dot com and we will take a look.
Tim
Tim Corey
Redding, CA
tcorey
Hello again Rich,
I looked at your drawing. The issue is caused by using Insert to insert a block, rather than using MvblockAdd to add the mvblock.
The interesting thing is that I find dragging from the ToolPalette works the same as Insert, so you get an incorrect object. Use MvblockAdd instead.
See the video:
Tim Corey
Redding, CA
richardKTHG4
Thanks Tim
Regards
Rich
