Goodmorning from the UK!
Working on a project at uni and didn't have access to a 3d version of the topographical data, i've done a bit of research and discovered that its possible to create contour lines from point data in civil 3d? (Hope I'm correct lol)
Anyway, i was wondering if there was any Civils out there with a few spare minutes of there time to have a crack at turning this data in to contour lines for me? Wanted to export the data to sketchup to look at some massings.
I've taken the time to edit the z value to its correct position for each spot height.
Cheers,
Reece!
what is your units? thats a lot of contour lines. what kind of interval are you looking for? with 1's and 5's it is a very dense surface (you've got a lot of grade change)
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
wow, that ballooned in a hurry, didnt expect the surface to make it a 60 mb file.
Attached is the contour plan of the topo. I've assumed it was in UK units (metres). Contour intervals 0.1m and 0.5m
It looks like the source info was a bit messed up, the survey point setting out was in millimeters and the Z values in metres, hence why such a huge dense file
