Allow some windows in the lower part of the toolspace pop out. For example, if you click the pipes in a netowkr, all the pipes show in a list in toolspace in a small areas on the bottom. Allow this area to pop out. It would make it much easier to edit styles, verify part information and rename parts as currently, the amount of data shown is small.
This is one where Autodesk just needs to add it to the right click menu. You can find what you are looking for from the Network Layout Tools.
If Autodesk doesn't grant this idea than I'd cancel your subscription. For if they can't spend 4 hours for your $1000 subscription you shouldn't be paying it. I'd be really pissed if I were you and Autodesk redid icons instead of adding this UI feature in Civil 3D 2017 that would really improve you productivity. Autodesk is costing you money, more money than it would cost them to grant your idea.
