Hello All,
I am new to AutoCAD Civil 3D 2016 and I have been struggling to plot my drawing. When I plot, I am not getting either of the feature lines or the TIN Surface to show. I have tried researching on the forum and seems like others have had this problem but their solutions did not work for me. I.e. I have checked to ensure the layers are on and unlocked, level of detail, audit, line weights and adjusted contour intervals, all with no success. Any other suggestions? I have attached the model file for reference. Thanks!
Most smart objects such as featurelines, corridors, surfaces, parcels, alignments, pipe networks and so on are controlled by the styles. That being said, those objects can also have parent and child layers depending on how yall setup your templates. For example if you go to your Toolspace/Settings tab and then right click on your drawing file name and select " Editing Drawing Settings" the Drawing Setting dialog box will appear. In the Object Layers tab are the parent layers that control many features So if you create surfaces or featureline that parent layer is used. So your surfaces and featureslines could possibly be on these parent layers. Then go to layer manager and see if these layers are set to plot.
Tony Carcamo
President/Owner
Civil CAD Learning Solutions
DFW BIM Infrastructure User Group
LinkedIn | Twitter | Instagram | DFWBIUG |User Group
If you still have issues, just email me your drawing and I can take a look at it for you.
Tony Carcamo
President/Owner
